05Single's virgin build thread. 03 tahoe
HiHoeSilver
Away!
Chicago
I thought you had to use HEAT to remove bolts with Yellow loctite.
Impact or my tried and true bfp
I may be wrong about the yellow. I just had a memory of seeing it. Might have been on the Ferd, too.
There are tons of different kinds /strengths. Enough that color isn't the end all be all. Red 271 vs 272, etc. Yellow may be an assembly line thing t,oo. I got mine out using the old two wrench trick, no problem.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Nah, doesn't look like you're wrong..... looks like yellow probably is assembly line grade like you said.
According to their website, red is the one you have to remove w/ heat...
http://www.loctiteproducts.com/p/10/15/t_lkr_red/overview/Loctite-Threadlocker-Red-271.htm
05Single
05Single
afraid of the dark
Well answer me this , what’s the torque specs on the caliper bolts ? It’s not much I don’t think, 100lbs? Found all sorts of numbers online
relx
