07-14 Fender height measurements
Tiki
Looking for leveled Tahoe fender heights. Please also include your lift/tires. Also if someone can verify stock measurements (with stock tires)...
Front - 35.5"
Rear - 37"
Really interested to see where 2.5" levels are with ~33s.
ScrewbenSS
At the moment im on factory 20's with factory size tires 275/55R20. I have the Rough Country 2" level on the front of the truck. 17" wheels and 33" bfg all terrains "should" be in tomorrow. If not then monday. I will get updated measurements then. But here is where it stands now on factory wheel n tire.
This is the front fender:
This is the rear fender:
Attempting a side shot for the look.
ta07hoe
2007 bone stock 275/60r20 36 front 38 1/4 rear. My 2" leveling kit should be here by the time I get home from work today so I'll update after install.
ta07hoe
Its not that noticeable in the pics in guessing because it's dark. It is a noticeable difference in person tho. Truck drives just like before. Top is stock bottom is after the 2" rough country 49.99 plastic lower spacer. So far it sits 37 3/4 in the front and 38 in the back. Before it was 36 and 38 1/4. I have 275/60r20. Before the spacer they would sometimes touch the sway bar and inside of the wheel wells. Never anything more than a little light rub mark was left. After the winter I want to get some 20x10 with a -19 or -24 offset and some 33x11-12.5's. Size will probably depend on who makes the tread I like and the cost. image.jpeg
ScrewbenSS
Upgraded wheels and tires. This is now where it sits with a 305/65R17 BFG all terrain K02. Wheel is 17x9 +10 offset. Brought it up a little but not much. Still only a 2" rc front level.
PG01
Up here to the right
ScrewbenSS, where did you get the blackout grill and bowtie or did u plastidip? Im looking for blackout grill and bowties front and rear, just curious if u got them from same place. I found some on ebay but alittle pricey... Thanks
Ciro
I replaced the front struts with ACdelcos listed on Amazon as OEM replacement and the truck got leveled without adding any leveling kit.1ad1578f5b8178f73965824e0d11a26a.jpgac0823d2b2cfff370b27385086fb9af9.jpgcdda009f64dea1fa927bafcf8e921dcb.jpg
ta07hoe
After 500 to 1000 miles they will settle In. New springs always said Higher like that. Where did it sit before
Ciro
Yes, it makes sense, Before I changed the struts it was sitting at 35", 800 miles has passed since I changed the struts and there has not been a noticeable change in height yet but I will check it again at 1000 miles.
TheZTahoe
