07 suburban.
lee.solorzano
I have white smoke coming out exhaust and slight shake in motor. Any possible idea. And dose any one now what 5z3 I can replace my motor with it aluminum block vin 3
OR VietVet
Multnomah Falls
Military
Willamette Valley
What @PNWTahoe said. Needs a compression test with all plugs removed and inspect the plugs and post pics here of the plugs. Likely, if it is head gaskets, the coolant is in the oil and the oil will look milky and will also show on the dipstick and under the oil fill cap. Is oil fuller than normal and coolant low?
lee.solorzano
lee.solorzano
I was thing head gasket. Just got the truck 2 days ago. Was taking to shop cause they said Tran might slip. Drive 15 min then I saw all the smoke every where.
lee.solorzano
lee.solorzano
I’m hoping not motor. It code 3 aluminum block hard to find
lee.solorzano
lee.solorzano
Just called the pulled in shop now to. Check it.
lee.solorzano
lee.solorzano
Any one know if I can put a 6.0 in it if motor bad. And how hard would it be
lee.solorzano
lee.solorzano
My truck I left at the shop 8 this morning now they pulled it in to check engine
mthompson47374
