07+ Tahoe Front Brakes: Lightly used rotors and pads
bmwme
I have a set of lightly used OEM front rotors and pads off my 2007 Tahoe. I got Hawk pads for towing and figured I would start out fresh so I got new rotors too but I could have easily reused these rotors. These can't have too many miles on them because there is tons of pad material left and the rotors are barely worn. I've put about 10,000 miles on the truck but I'm not sure how long they were on it before I bought it. It was a certified preowned so I wouldn't be surprised if they were replaced at the dealer.
I can take detailed pictures if you want. The rotors have normal surface rust in the unswept area but no grooves or cracks.
This would be perfect for someone with front brakes well past their life who wants to get like new brakes for a big savings. OEM rotors are anywhere from $50 to $100 each and pads around $100 for the set. I'm only looking for $50 plus shipping (which may be a lot due to weight). No low ball offers, anything under $50 and I'll probably just keep them as spares. Thanks
-Jeff
B
bmwme
will these fit the NBS? (00-06)? I think they are bigger
I know they upgraded the brakes for 07+ so these likely won't fit without upgrading the brakes. Don't take my word for it though as I know nothing about the NBS.
Alex33
You have to upgrade to the 07+ calipers and brackets to use them since the rotors are a larger diameter.
^^ This. Still a good bolt-on upgrade for NBS trucks.
Great pricing assuming the pads/rotors are good. GLWS.
Alex33
Get 'em Heath!! Then you just need calipers :D
Alex33
Check amazon. A lot of guys that do the mod get rebuilt calipers from somewhere on there, not sure on pricing though.
Capeles
