07 Tahoe LT w/Bose adding an amp with PAC-GM1416
yates ™
Resident Apple hater
Iowa
What is different with the Y91 coded vehicles?
robdeniro0
Just figured this out today after calling PAC audio. pac1416 works with all bose systems except those with the Y91 premium code. There is a sticker in the glovebox that has the codes...If no Y91 then it will work.
Man after all of my searching a definitive answer! Your the best hybrid:Handshake:
robdeniro0
Oh well i have that code so no workie for me, good to know though.
09tahoehybrid
Ohio
You can just go with the PAC SNI35...not plug & play, but not a hard install.
---------- Post added at 04:11 PM ---------- Previous post was at 04:11 PM ----------
Hmm...will the PAC 1416 totally bypass the stock amp? I was planning on letting it power the rest of the stock speakers & and just add another amp for the sub only.
MattyZ
MattyZ
Oak Harbor, WA
Right now I have it hooked up, but nothing connected to the RCA's. My stock stereo and everything else works as normal. I currently have a sub amp hooked up using the hi-low converter, but will try a set of RCA's to see if it cuts out before I add my other amp.
09tahoehybrid
Ohio
In that case I'm already wrong...I thought you had to unplug the stock amp plugs from the back of the headunit to let the PAC plugs go in.
matty40
