Looking for some feedback on what my next step should be. I have been throwing code P0442 about every 3 weeks for about the last 4 months. So far I have sequentially replaced the following components
OEM Gas Cap
EVAP Canister Vent Solenoid Valve
EVAP Ccanister Purge Solenoid Valve
EVAP Vapor Canister
All my hose connections seem to be tight and clean. I have once again set a check engine light with P0442. I have used the search forum search function but I haven't found anything that mimics my scenario. In most folks cases one of the four items above resolved their issue. Question is do I take it into a shop capable of performing the smoke test or is there another component that could cause the issue which I haven't covered yet. Any thoughts on items I should examine that is not covered on the list above? I should mention that either ACDelco or GM parts were used for all replacements.
I do not have any other codes being thrown and I also do not have the characteristic hard to fill gas tank either. I have the computer based ScanXL software I can use to interface with the vehicle if there is something I should be paying attention to there as well.
Thanks
Mike
OEM Gas Cap
EVAP Vapor Canister
Thanks
Mike
