07 Tahoe wheel question.
prman1970
NYC
I exchanged my factory 20's for the summer with 22" 305/40/22 wheels. Besides a wheel alignmnet and balancing of the wheels is there anything else I should be concerned with?
Thanks,
mdtahoe
If your alignment was ok before then it will still be ok. Wheels do not change the alignment, however it is generally good practice to at least have the alignment when new tires are put on.
P
prman1970
NYC
Thanks mdtahoe. The reason I asked is becuase someone told me if I take long trips there is chip that needs to be installed so that the tranny does not burn out??? I found that very hard to believe.
OMG its Jason
Orlando, FL
Never heard of that...
As far as that slignment suggestion. lol, usually when switching from 20's to 22's, there's gonna be a new set of tires so an alignment would be good ;)
Nfamous60
Bronx, New York
what about he speedometer being calibrated for the larger wheels you may be going faster then you think!
P
prman1970
NYC
The speedometer being calibrated makes more sense. I will look into that.
Thanks.
Hawksfan71
