07 Vibration hitting bumps
H
hhrpdr
Yes they still have our vehicle and no I would not like to file a complaint yet. We will see what they can come up with this time around.
GM Customer Service
Michigan
hhrpdr,
Please let me know when you get your vehicle back. I would also like to know if the issue does return.
Thank you
Elizabeth, GM Customer Service
H
hhrpdr
Got it back. Replaced u joints. And front end noise ended up being a service bulletin. 10-03-08-002A. Now I should let you know this tsb was not diagnosed by the dealership it was by a friend of mine that works for a honda dealership. He had diagnosed an avalanche that had the same issue. Can anyone explain why they didn't research this and find this out, but someone at a honda dealership did.
GM Customer Service
Michigan
hhrpdr,
I’m glad that you got your vehicle back! Unfortunately, I can’t determine why your local dealership did not research the issue. You would need to confirm with them. I do apologize for the inconvenience. Please let me know if you have anymore issues with your vehicle.
Thank you!
H
hhrpdr
Well the vibration is still there. Elizabeth if you are curious why this dealership is not researching these issues before they say its "fixed" you can call and ask them. Ryan auto mall buffalo minnesota. I am finding out more that is wrong with these than they are.
GM Customer Service
Michigan
hhrpdr,
I would like to look into this further for you. Could you please message me your full name, address, phone number, VIN and current mileage? I would appreciate it.
Thank you!
H
hhrpdr
I do not have enough post to private message. Could you private message me an alternate way to contact you. Thank you
HUNT4WHEELS
50k and I had to change out the shocks also... Rears only and noise went away.
H
hhrpdr
Guess I might have to try that cause the noise is still there after another visit. Got a knew drive shaft this time though. No vibrations at higher speeds, for now.
---------- Post added at 05:28 PM ---------- Previous post was at 04:14 PM ----------
You had the same issue when hitting bumps? What did it cost you for shocks?
Paul french
