07 Yukon w/ P0449 error code
FireDawg212
Mississippi
I have researched the threads here with folks that have had the same code pop up but I'm seeing different symptoms. Most of the talk here concerns the tank fill issues. The only outward trouble I have experienced is the fact that the CEL causes the remote start to not work. Can anyone share whether or not the EVAP system is the only one that throws this code or is there another underlying cause?
Any help is appreciated!
Mechahead
Dallas, PA
There are other things that cause this codes, but they all pertain to the valve and the wiring for it. I have seen the valve itself bad and I know a time or two I found the wiring up near the front driveshaft worn through. If there is nothing visually wrong with the valve and wiring, you would need to command it with a scan tool and look for voltage at the lead.
I also would like to add there was a bulletin that pertained to this code on some models with a relocation of the vent opening. Road grime and what not was getting directly into the valve and causing it to corrode from the inside out.
GalaxyBlackEsky
BlackedoutLT3
MD
Replace evaporate canister above spare tire. That is what the code is for.
TheFuzz
Idiot Police
Spurbury, VT
Yep, evap solenoid/vent tube assembly. It's about $40 worth of parts and 20 minutes of your time. It was one of the first things I had to do when I bought my truck in April...a couple of bolts and a few zip ties and you're done, no biggie. There's a good how-to on Youtube if you search for it.
F
FireDawg212
Mississippi
I finally got around to replacing the evap solenoid & tube assembly yesterday and the light went out shortly thereafter. It stayed out for about 24 hours and came back on this evening. I guess I'll take it to the parts house to hook their scanner up to see what's up.
F
FireDawg212
Mississippi
Cleared P0449 now seeing P0446
OK, as I mentioned last week I made the suggested replacement of the evap solenoid & tube assembly and the CEL cleared for a little over 24 hours. I stopped by the parts house and the code that has popped up now is P0446. It seems that these are similar parts from what I've read? I need to know what to do to clear this out completely! Please help me out with this!
Skylander
