@BSarteSr - I had to respond to your Tailgate Latch / Liftagate Latch thread posing.
I just did fix my wife's 2007 Suburban powered liftgate which suddenly quit going up on about May 03, 2022. Great Scot.
So, after hours of scouring the net for wiring diagrams for circuit chasing, I came across this Posting of yours.
I disassembled both the Liftgate motor-drive mechanism, and checked the solenoid clutch for operation and the gear teeth, with all lookng newish. Solenoid clutch electrically operating just fine. ( reminds me of an a/c clutch ).
So, here is the hard cold truth:
I took my wife's '07 Suburban 2500 4x to the local dealer and was quoted $1,785 smackers for new Liftgate assembly, Latch and struts. Technician indicated liftgate motor failure and latch and struts. OMG
I am 70-years old, and my dad was a lifetime gm parts guy, so I am used to considering parts Interchange.
I ordered GM part #84243380 Liftgate Latch from RockAuto and was delivered yesterday at 11:30am.
I unpacked it this morning and took me a whopping 20-minutes to install. I pushed the upper console switch from 'disable' to operational position, pushed the lift actuator switch and the Powered Liftgate unlatched and went up as it should like Normal. Yeeeeaay.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
big smiles.
For those concerned or having powered liftgate / tailgate problems here is the deal. (my conclusion) read below.
I disassembled the latch assembly looking for a switch which communicates sending a signal to the module attached to the Liftagate assembly. I was able to only remove the electric motor and bull-gear (ring-gear white plastic). All was good. I couldn't disassemble anyfurther, so no evidence of the "suspect switch" communicating with the liftgate module.
Now that the powered Liftgate Latch / Tailgate Latch is operational again, I'm going to perform "Open-Heart-Surgery on it to find the ghost switch which is apparently not working.
An electrical switch can only open and close a certain number of times before the contacts become corroded or compromised and fail to make a good connection.
Relay's go bad because they are an electrically operated switch closed by a solenoid activated by the switch circuit.
Each time I have had a Relay failure, and circumsize off the plastic cover exposing the contact points, they operate as designed once cleaning the point contacts.
We can do this in an emergancy on-the-road if you have a hacksaw blade to cut and remove the relay cover.
Easy Peasy.
Moral of this comment:
If your powered Liftgate or Tailgate is not powering-up, chances are the hidden switch in the Latch has failed.
Today I am One-Happy-Camper.
