I appreciate your candor and I share your sentiment. But what I can I do about it? I'm at his mercy.
I don't like this being with him any less than anyone else would. Honestly, now I'm concerned that if "sludge" clogged the ports from "detergent" in the oil, that caused the lifters to stick enough to grind down the cam, then ... what about the odd-cylinder side? Will I have to replace that next?
I appreciate you being receptive and not getting butthurt about such candor.
More candor: What can you do about it? You can do what was suggested to you a long time ago- remove yourself from his mercy. It was suggested to you multiple times back before this had been drug out (and escalated?) to get your truck back from him, but your replies every time were you essentially surrendering to and defending him. Why? What power does he have over you? There has been so much BS this guy has been feeding you but you sum it up as just jokes cuz he's just a funny guy. If you want a laugh, buy a ticket for ~$30 and go see a comedian. Don't pay $1,600 multiple times and upwards of $4,000 to a "mechanic" for a laugh. If you had agreed to pay him a big stack of cash to replace the motor, would he suddenly get serious and tell you that he was just joking and that you don't need a new motor, that your piston actually IS reaching TDC and that he didn't really see what he told you he saw with his bore scope? Hell no he wouldn't! He keeps throwing stuff at you until he finds something you're not gonna question paying him to do. If you call him out on his lies and put him in a corner, he easily gets out by laughing it off and convincing you he was kidding cuz you two are just two friendly jokester buddies like that. Then he finds another lie to try on you...
Let's say that there actually isn't anywhere else local for you to take it. You could've gotten it and let it sit parked in your driveway for the past few weeks. At least it wouldn't be at this scammer's place having who-knows-what being done to it and likely racking up an unnecessary bill. It'd be safe under your watch and accessible for you to bring somewhere once you found another shop. I'm not believing that there are no other options for you. Bringing it to a reputable and competent shop a city or two away where it could be quickly properly and accurately diagnosed and quickly and probablly cheaply repaired would far outweigh the inconvenience of having to take it a few miles further.
A sticking lifter isn't gonna grind down a cam. It'll just tick until it unsticks. If it doesn't unstick and gets beat up, then it could come apart and do damage from the fragments going into the oil stream, etc. A sticking lifter could possibly get knocked around and rotated if it breaks the retainer tray. THEN it would grind a lobe because the wheel on it would be be sideways on the cam lobe and not rolling. Picture a car being T-***** and pushed sideways with it's wheels skidding on the road- that's what the roller on the lifter would be doing on the cam. Oh- sanding the head or block or whatever he said he sanded... No he didn't. Doesn't matter if the block is aluminum- the cylinders are steel sleeves. The mating surfaces of the block and heads has to be 'perfectly' flat (within .004", I think is what GM specifies). Also, the heads have to have an RA of something like 20-40, which looks like a foggy mirror. You're not gonna get such surfaces by hand-sanding and especially not while in the vehicle. Just more of his lies and technical jargon being used against you.
