08 Tahoe Rear AC not blowing cold
denalianyone
NYBlackLade08
New York
The larger line should be cold and sweating. After reading the suggestion that the valve might be stuck, I'm thinking this could be a possibility resulting from lack of use. My Tahoe sits a lot.
Did you fix your issue? There are two orifice tubes in the rear that need to be checked if air is struggling to get cold. Now if the high side line is cold underneath and not cold air in the rear, then the blend door is the culprit.
hosleyb
