Now I've read about the previous generations power door switch going bad often, but I don't read about it in 07-14s
My driver side window switch is not working, no up or down. Motor works fine with a separate 12V power source going to it.
I've checked the power on the plug going into the motor and it gives out only 5V. I tore apart the driver door switch assembly and there was no corrosion at all. All fuses are fine and there's no other issues.
Should I be looking for a power wire that is corroded somewhere? Or does the driver door switch need to be replaced along with the coding?
