09 escalade rim question
09escaladehybrid
So my 09 Escalade (hybrid) started giving me a low tire pressure reading. After airing up the offender and keeping an eye on it, I confirmed that it's leaking. I checked the valve stem and core with dish soap but no bubbles so I took it to the local tire shop. The Michelin's have about 15k miles so they're in good shape. The tire guy showed me that the 22" chrome over aluminum rim was flaking off which keeps the bead from sealing. It's also been below zero for days so that doesn't help either. Rather than replace the 4 rims with aftermarket's made in Asia for $1,200, I'm wondering if I can just put tubes in the tires ($150). I've done this with other setups on trucks. Does anyone know if this will work on the Escalade? It almost seems too simple but thought I'd check for your thoughts. Thanks in advance.
j91z28d1
I sometimes put tubes in low speed non dot tubeless tires if the rim has issues with rust and it's hard to get a replacement or the unit is due for scrap within a few years. it seems to work fine, just makes them kinda annoying to unmount.
does anyone even sell a 22in tube that would work in a low profile tire? you should use the correct size, if they are to big they have folds in them and over time the folds are where leaks start. other that that seems like balancing would be the only big concern.
but for me, you can't see the inside bead. if it was mine I'd just hit it with a wire brush attachment on something high speed and knock all the flaking chrome off. put the tires back on and go?
B-train
I'd never consider putting a tube in a tire capable of high speed, especially in a 22 inch wheel. $1200 is way cheaper than an insurance claim or personal injury. If $1200 hurts your wallet too much, then check out FB Marketplace for a set of take-offs that are in good condition.
Tubed tires are for old hay racks, old tractors, and for floating in a pond.........
I've had similar issues with my 20" wheels. First, you need to find a local shop that will take the time required to properly prepare the surface of the wheel for tire mounting. My shop uses an air powered rotational tool with a very mild abrasive wheel, and they smooth out the entire surface of the wheel, where it contacts the tire bead. Then, a quality sealant is applied to the wheel/tire contact areas, and the tire is mounted. I have never had a continuing leaker, after using this method and taking the time to perform the work properly.
petethepug
Michael
SoCal
My 22’s are doing the same thing. The cure is what JG just pointed out. I’ll see if I can get a pic of the black tire sealant they used on mine at the shop.
tooleyondeck
Northwest FL
Probably wouldn't be hard to find a replacement OEM wheel on marketplace or, worst case, eBay. You have several options here besides buying a complete set of replicas. Replace, repair, powder coat, etc...
petethepug
Michael
SoCal
I’ve replaced one of mine with an aftermarket rim and the chrome quality was inferior. They do rechrome them or strip and powder coat them.
Ironically, a lot of places will say they can not be stripped. Nope, not true.
Read the reviews on the sealant. For now, I’d go this route.
Xtra Seal Tire Bead Sealer 32 oz Black w/Brush Top Can PRO Quart
https://a.co/d/4kzPryP
11bravo
Las Vegas
I realize this might get me banned...would a good tire sealant work on a bead leak? Most probably know, sealants have come a long way in recent years. Less gunk on the inside of the tire, and no chance of blow-ups. Maybe I ask because I'm sometimes cheap...but would it work?
Geotrash
Dave
Richmond, VA
I've already reported this post to the moderators. :happy175:
The problem I see with that approach is that centrifugal force would seem to keep the sealant against the tread and upper sidewall area. I wonder if the sealant would even get up to the bead. Might take a bumpy road to make it happen, if so. Either way, wire brush to remove the scale and then regular tire bead sealer works well in all but the most extreme cases - and in those the wheels probably should be discarded anyway for questionable structural integrity.
HAIGDEDNEDNA912
