markelee66
- Joined
- Oct 19, 2025
- Posts
- 10
- Reaction score
- 13
We have a 2009 Tahoe LTZ with the 5.3L Flex Fuel. It has about 45k miles so very low mileage for the age and it's been well maintained. In the past few months we've had a few times, 3-4 where we experienced a long start. The starter turned way more than normal but once it started it was smooth, no rough idle or anything I think of when talking about a hard start. The other day when pulling up to a stop light there was a little surging. I thought it was the transmission trying to decide what gear to drop into. While sitting at the light the engine died. It cranked right back up but a moment later died again. It started again with no real issue and ran fine the half mile or so home. Once home and sitting in the driveway we could hear what we think was the fuel pump making a loud noise, basically a vibrating sound. There was no CEL and no pending codes when I hooked up the reader. Little bit of Google searching says fuel pump, throttle body, failed torque converter clutch. The fuel tank is not the original. It was replaced by a mechanic when trying to fix EVAP codes. We had hit the point we thought it was the valve/really that is in the tank and not serviceable, so I don't know any history of the tank and the fuel pump. Because of that and the unusually loud vibrating sound we're hearing from the fuel tank area, I'm leaning toward that being the problem. However, several of the searches point to a dirty throttle body. I'm wondering what the odds are of it being the throttle body with the lower mileage it has. I also found it has a fuel pump control module so I suppose the computer could be on the fritz. Looking for any input to get a solid diagnosis as I don't want to spend $400 on a fuel pump, drop the tank and all that work and it not be fixed. You know the drill. Thanks in advance for any infomation.
