YukonandtheHOE
- Joined
- Nov 11, 2016
- Posts
- 394
- Reaction score
- 181
Edit- had a Blonde moment, with no filter. Fitment is 100% with the converter all the way engaged.
Good idea my man. Valley pan incoming first thing tomorrow. Short of that, it must be software if the injectors aren’t firing and the ecm is ok with that enough to adjust afr that the o2’s aren’t freaking out and the exhaust doesn’t smell to rich.@YukonandtheHOE If you have an AFM VLOM you should be able to plug it into the existing VLOM plug on your engine wiring harness and hang it next to your engine and that should let the motor run properly if that is your problem
