100k service?
HiHoeSilver
Away!
Chicago
That's interesting. Is that a new thing? I've been watching some videos and they use moog. But if the ac delco is recommended I'll swap that out
Not new. I haven't done mine yet, so I'm just citing what I've read by others as I've researched my job /mod list.
@HiHoeSilver
Ac delco professional?
And is it worth twice as much as the advantage?
Yes. "advantage" is a subpar line. OE or professional, imo.
@HiHoeSilver
Just want to say my OCD wants to thank you. I swapped the pitman, idler arm and bracket to all ac delco professional and they are all Prime lol
Again, not sure if it's the idler or the pitman. It's one of them. I know you've been open about not searching... But you need to search, bruh. Lol.
Bombsquad85
Bombsquad85
Northern VA
Lol I searched for the suspension stuff just not what is recommended for 100k service lol.
Plus I'm pretty knowledgeable with a wrench lol I appreciate you're advice tho I was unaware of the moog problem. I've had great luck with moog so far at least the problem solver line up
HiHoeSilver
Away!
Chicago
No doubt. Problem solver all day. Just looking out as there have been threads dedicated to ONE of those parts not fitting right.
Chubbs
Accessory drive belt
Type:
Service/Inspect
10K
20K
30K
40K
50K
60K
Service:
Air cleaner filter
Type:
Replace
24K
48K
Service:
Automatic transmission fluid & filter
Type:
Replace
50K
Service:
Automatic transmission shift linkage
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Brake fluid level, calipers, wheel cylinders, hoses, lines
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Brake rotors, drums, pads, shoes
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Clutch release lever
Type:
Service/Inspect
30K
60K
Service:
Clutch reservoir fluid level
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Cooling system hoses and clamps
Type:
Service/Inspect
15K
30K
45K
60K
Service:
Crankcase emission air filter
Type:
Replace
30K
60K
Service:
Engine coolant—DEX-COOL™
Type:
Replace
Replace every 150,000 miles
Service:
Engine coolant—silicate
Type:
Replace
15K
30K
45K
60K
Service:
Engine oil & filter
Type:
Replace
Change when indicated by the Oil Life Monitor, every 12 months, or every 10,00 miles
Service:
EVAP system
Type:
Service/Inspect
60K
Service:
Exhaust system & heat shields
Type:
Service/Inspect
30K
60K
Service:
Front & rear driveshaft slip-yoke
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Front wheel bearings
Type:
Lubricate
15K
30K
45K
60K
Service:
Front/rear axle fluid level
Type:
Service/Inspect
3K
6K
9K
12K
15K
18K
21K
24K
27K
30K
33K
36K
39K
42K
45K
48K
51K
54K
57K
60K
Service:
Fuel filter
Type:
Service/Inspect
30K
60K
Service:
Fuel system
Type:
Service/Inspect
60K
Service:
Manual transmission fluid
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Parking brake system
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
PCV valve
Type:
Replace
30K
60K
Service:
Power steering fluid
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Rotate tires
Type:
Service/Inspect
6K
12K
18K
24K
30K
36K
42K
48K
54K
60K
Service:
Spark plugs
Type:
Replace
30K
60K
Service:
Spark plugs—Platinum
Type:
Replace
Replace every 100,000 miles
Service:
Steering linkage
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Steering linkage and suspension
Type:
Lubricate
3K
6K
9K
12K
15K
18K
21K
24K
27K
30K
33K
36K
39K
42K
45K
48K
51K
54K
57K
60K
Service:
Suspension components
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Transfer case fluid level
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
Service:
Transfer case shift lever
Type:
Service/Inspect
5K
10K
15K
20K
25K
30K
35K
40K
45K
50K
55K
60K
relx
