'16 Escalade Trans question
Dino615
So l had a condenser go out and had to change it. I obviously lost that fluid that was in the cooler as well as what leaked on the ground. Now I am experiencing shifting issues from 1st to 2nd. Has anyone actually installed a dip stick on their Escalade? If so, do you know the part number, or model year to order it from? I obviously can't order a part that never came on the vehicle.
Thank you.
the tube should be 24267838
and the dipstick could not find the part number but any 15-20 tahoe, yukon, suburban, denali should be the same
as far as fluid loss unless you lost more than a pint or 2 it probably would not be the source of your issue
clean the intake, new air filter, clean the maf and throttle body as those send shift information to the computer
B-train
Is that a number for the 6 speed or 8 speed trans? Or does it work on both ot them? I've been wanting one for my 2017 so I can do my own services.
B-train
See my previous post. Forgot to link you the first time
I didn't take into consideration if that was for a 6 or 8 speed, i just looked up for suburban.
so my info could be wrong but any dealer parts department can provide the correct one for a 6 or 8 should all be the same for either trans across all brands.
they don't make a different one for a tahoe or a yukon as long as it is the same transmission
B-train
Gotcha. The 8 speed doesn't come with one, so I wasn't sure if there was an actual number for one, or if it's an aftermarket thing. I'll do some snooping
I have read some of the corvette's did not come a transmission dipstick and some people were putting one from something on them but I don't have any details
B-train
I looked at the silverado forum and I guess a dipstick from a 2016 camaro will fit. I might look into it. Or, I'll just pay to have it flushed every 40k and call it good as long as there are no leaks. But, I am super old school and like to be able to check stuff before trips, etc. I hate cost cutting that forces a. Dealership visit..........#grinds my gears. LOL
I am as well, my 18 silverado has a dipstick so have not ran into this issue but I make it a habit to use a flashlight and look under my vehicles on a regular basis to make sure there are no leaks from anything, if it's not leaking then it should still be full
D
Dino615
Thank you everyone. I think I will start with a flush first and see if that helps/fixes the issue. I will look into the part numbers for that part. Maybe do an Amazon order so if it doesn't fit I can send it back.
Mirek
