16 Yukon Rear Glass
Atstew01
My rear glass won’t open, is there a way to force it open? I believe the latch motor has gone bad.
dbbd1
Just to confirm...
The rear glass only, not the whole hatch?
Do you hear anything when you press the release button?
Checked the fuses?
Atstew01
Atstew01
Just to confirm...
Checked the fuses?
Yup, rear glass only. I checked the fuses. I think I hear a relay click, and the mechanism move and 1 time out of a hundred, it opens.
dbbd1
Cold weather where you're at?
I would try getting that thing to open and when you finally do, shoot some silicone spray on the mechanism.
It's just a pop-open type plunger, there is no motor to close it (nor open) like on the big hatch.
dbbd1
And...
Try it with the fob. How's it work?
dbbd1
I suppose that you can open the hatch, pop off the trim panel and manually trigger the latch. Then lubricate the snot out of it and see what happens.
tony97218
