17's on Escalade for Winter
jrobie79
Does anyone know if 17" rims from a 2006 silverado will fit on the escalade? Specifically these:
I want some crappy wheels to put some snow tires on for the winter. It's a pain finding reasonably priced snow tires above 18", although I am looking for the base escalade wheels.
05alive
Masshole
Yes. Same bolt pattern. Should be similar offset and backspacing.
Meccanoble
Georgia
Well Tahoe has as low as 17's and if all 3 (tahoe, caddy, yukon) are same, I see it fitting with no issues. Nothing is different between brakes on the cars so should be no issues. In fact, you may get more comfort with the thicker tires :)
05alive
Masshole
the base models have 18" on the 2007-2014
Didn't look at what body you had, my bad. Saw 06 silvy wheels and assumed nbs escalade.
Iirc 17's will still fit nnbs vehicles. Only need to trim for 16 or below.
Speck
Olympia, WA
They also are capable of running the 17" steelie transport wheels as well. I run a set on my 08 Denali for winter setup and have no issues. It is VERY tight clearance on the caliper, but they do not rub.
Joe
jkiger95
