1995 yukon starting issues?
_Dylan_
STAY FROSTY
Ok you need to give us more details man your not helping us help you.
Is the starter cranking and the engine won't start? Or the starter doesn't crank at all? If it's not cranking can you hear the starter solenoid click when you turn the key?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
when i turn the key on tha dash lights up then when try to start it nothing... has only happen twice in two weeks since i owned it.. goin to check and replace battery cables
yeah if the moment you turn the key everything dies if that is what you mean either something is goofy with connections, ignition switch or battery supply.
---------- Post added at 07:18 PM ---------- Previous post was at 07:17 PM ----------
just try cleaning them first dont spend money on stuff unless it is damaged somehow.
C
cburns002
WHEN i turn the key nothing.. all dash lights up, can hear fuel pump but no crank no attempt to crank.. NOTHING....its like its no battery connection but after bout 15 - 20 mins then its fine. and will start like there is nothing wrong..
_Dylan_
STAY FROSTY
Go over the battery connections and clean them and tighten them up. Or if the cable terminals are worn out, buy new ones.
gy_psi
