1996 door hinge bushing
rpitts
Just changed the bushings. Anyone know of a good trick to get the big spring that holds the door open back in where it goes?
95escahoe
they sell this tool at the parts store that compresses the spring so you can take it out and put it back it, picked it up when I did mine
R
rpitts
any idea of what this particular tool is called? I know the make coil spring compressors, valve spring compressors (which are about the same size)....I'm not sure if the people at my local Autozone are that knowledgeable.
95escahoe
honestly not sure, when I did my door pins got all the parts plus that tool at napa and looked on there site and didn't see it, and its different looking that the ones you listed, someone on here should know
badadatude
door spring compressor
_Dylan_
STAY FROSTY
I was reading up on this a while ago. Some guy said he compressed the spring in a vice and ziptied it. After install he just cut the zipties.
badadatude
Hhhhmmmmm dont know if I would trust using zip ties. The spring has a fair bit of tension when compressed. Spring compressor was only bout 5 buks and saved me alot o hassle when I changed my door pins
Chevy_Boy1990
