SunlitComet
OBS Jedi-Do Good
along with your temp you would need the other data in the test to determine if something is out of place. a two degrees swing of temperature that is dependent on rpm is of no concern at this point tho.
Just as reminder, on a hot day, it has to run on max to almost be comfy. back seat people will be losing water weight!ok, its warming up here where i live and sometimes still have this issue. I took video of truck running with ac on max. Is it normal to cycle like that??
