1997 chevy tahoe won't start
SunlitComet
OBS Jedi-Do Good
unknown at this time.
don't forget there is a relay for the starter that is in the system as well. you will find it in the under-hood power box. it is the actual power switch for the starter solenoid.
Chip18
Dayton NV
Neutral safety switch?? I have no idea where it is ... just a thought.
BladeMaker
I would trace the ignition wiring with a multimeter. If you have an aftermarket remote starter and something burned out inside that could be it. The remote starter box is fused. And if you trace all the wires to and from the box you will find a fuse somewhere. Check that. I'm assuming you already tried switching out the starter relay with the fuel pump relay (I think they are the two which are indentical). I would nultimeter test, for example, the pink wire on one side of the remote starter and then check for same voltage on other side of remote starter at same wire. Could be something in there messing up. That's if your issue is with the remote starter. Check all the wires this way. Check voltage with ignition off/on/cranking. Sounds like an electrical issue. If u trace all the wires you will either find the problem or eliminate it as a possibility.
BladeMaker
Someone on here can probably explain the ignition wiring specs or has a diagram that could help
Joe03z71hoe
