2/2 On 2DR 4x4, Help!!!
BennyR72
Los Angeles, CA
Trying to figure out how to get a 2/2 drop on my 96' 4x4 2DR hoe. I've got the front figured out with lowering keys and was planning on using shackles for the rear but I've been told the most you can get out of shackles is 2" because of the fuel tank nozzle, heard it might be possible to mod the hangers off a 4DR to do it.
Anyone out there done this or have any ideas?
Thanks.
Arctic-Rodz
RGV Texas
if you want a 2/2 drop you already figured it out. drop shackles will give you the 2" rear drop you want. anything after that im not sure
Da90
Tulsa, OK
If your wanting more than a 2" drop in the rear you have to go with spring hangers or a flip kit. Shackle hanger kit will give you a 4" drop. If you did a 2/4 drop on yours it would sit level.
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
front = belltech keys, rear = belltech drop leaves and 2 in shackles
all you have to do for the filler tube is strap it up to the trunk floor
you will get a 3/5 drop like that without a c-notch,but do remove the rear bumpstop brackets
TOWRIGG
BX. NEW YORK
just did my 94 2dr....keys in the front 1-3 inches..and beltech #6700 for the rear...didnt quite bring the rear down enuff for me so im going to #6400..on factory hangers..
Rfunes
