KMeloney
- Joined
- May 2, 2009
- Posts
- 3,001
- Reaction score
- 373
Thank you sir...you truck inspired me actually...now i want ur brakes and wheels!!!!!!!!!
Hey, thanks! You obviously have good taste.
On a side note: the addition of Tony's rear kit to the Belltech set-up is like night and day in terms of the ride and handling!
You talking about the relocation brackets for the rear sway bar, and the new shorter end links? If so, please tell me more about it. I'm thinking I want to add this to my truck. How was the install? What about the ride got better? More info, please! Thanks!
Yes KM, I was referring to the DJM brackets,Links, and shock extensions. I did not do the actual install, but my mechanic said the only tough part of the install was lining up the bolt holes (he had to strap the axle to pull it forward a little to get them to line up). As far as the ride, it just seems smoother. I had a minor vibration when I would accelerate through 55mph; that is largely gone now. I had previously added Eibach sways front and rear - now with the shorter endlinks, it actually feels like the rear bar is doing something! Cornering is vastly improved (especially noticeable when exiting freeway; around town, the truck simply doesn't seem to lean as much or push in corners). I would definitely recommend the rear kit!
My only concern with my ride now is that, with the spacer in and Belltech links as short as they go (I think that's about 2.75" center-t-center), the rear seems a bit "softer" than I'd like. Changing the links from 3" to the shorter length appears to have lowered the rear from 34 7/8" to 34 1/2", which I'm happy with, just not to sure about the ride being less firm in back??
If I knew that I could take the spacer out, set the links to 3" and keep the 34 1/2" height, that 'd be my next "to-do".
Well be waiting...post some when you get it...
Did your ride get a little sportier? i feel like mine is slightly stiffer, but dont mind it...
