2/3 drop practicality
bdesr32
Torrance
Im thinking of doing a djm 2/3 drop(keys and springs), first ? does the rear hardware kit need to be ordered as well and what about different shocks, or can I retain the original?
But my main concern is hauling. After all it is an suv with room for ppl and gear. Who has this drop, and how is the ride? Are you still able to load up your truck and speed around town, not worry (too much) about speed bumps and potholes?
Thanks in advance
MOBmentality
Has a $25,000 Punch
im not a fan of keys.. but a 2/3 drop in general has the capacity to by a stock tow and ride.. you can (should) do a shorter shock to retain full towing capacity and ride quality.. if you do spindles or lca on the front youll be happier than with keys btw imo.. as far as stock like retention.
you can tow on a 3/5 with 24s and people in your ride for the record.. so a 2/3 and 20s or so will be fine.
The hardware kit is more important for bigger drops.. 3 isnt that big of a deal.
blueflamed03
Oklahoma
I have a 2/3, with shock relocators, and I just changed out rear shocks to obtain max drop.
waxworkz
i had 2-3 drop on my suburban and hated the damn ride. even with shorter shocks. finally happy with my air bags, i ride lower and better
Z-56 Hoe
What do I do????
Houston
I have a 2/3 drop upgraded shocks and pot Helper bags in rear just towed a 6'12' trailer from colorado springs co to houston tx no problams the air bags were a extra $100 wow not bad and two of us in truck pluse a 100lbs dog and a 40lbs dog in the middle.
NoPh33rRaCiNg
Kent, WA
I have a Belltech 3/5 on 24's (stock shocks) it rides great and I towed a 26' RV, with 5 people in the Tahoe with no problems. It dropped my rear down to what i wanted it (lol) with about 1/4'' gap between the tire and fender and it didn't rub at all.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
dam look at your front wheels major camber. you running keys/spindles huh
ludvball
Where you using a weight distribution hitch when you towed that trailer? I am doing a 2/3 drop with the spindles. I plan to pull a Jeep wrangler on a trailer from time to time. I also plan to have a weight distribution hitch. I was wondering if I would need to consider helper bags for it.
NoPh33rRaCiNg
Kent, WA
No I just have a standard 5000 pound hitch on there. I need to upgrade it though, the trailer barely was under 5000 pounds.
Saucy_Walnuts
