turboeclips
Mine does the same thing.... that is the traction control light flashed a couple of times during turns.
I read all about this prior to doing my install and heard about making sure to disconnect the ABS sensors. I did so and am sure when I dropped the rearend, the cable was lose with no pull on it at all.
I dunno if there is a fix for it, this is the first I hear about that GM article. I do remember that there is 2 different situations.
1) People how have the traction control or ABS light on constant.
2) People how just have it come on when turning.
- I thinking that if it is on constant then you definitely damaged the sensor.
- If it comes on only at turns, then its something else.
I remember reading about someone who had it come on only when turning. They took the drop kit off and put stock suspension back on.... no longer had this issue, so it was something with the sensor not liking to be a a lower stance.
