2/3 vs 2/4 drop?
Bass911
I'm sitting at 34 1/8" in the front and 36 1/8" in the back on factory 16s. I'm assuming it would be better to do a 2/3 drop on 26s because I think the back would sit lower than the front with a 2/4 drop? Is this correct?
Bruizza
It would be damn close to lower if not lower. I dropped mine 2/3 on 26s and it is damn near level. I would think an extra inch in the rear would make the rear sit lower.
robstor
Yeah but I depends on the torsion bars. You can make the difference up with a little adjusting of the torsion keys.
Sent from my Lumia 710 using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
This depends on what spings gm used in rear (some sit lower /higher) In front can vary where the torsion keys are put.
If you do 26s i would do the 295 30 26 and this drop kit
http://www.tbssowners.com/store/index.php?act=viewProd&productId=86
295 30 26
26x10 with 30mm offset
Any questions just ask.
Tony
B
Bass911
cj 1990
