2 door Tahoe 3" Body lift questions?
wicked2000
El paso TX
I did a 3" body lift from summit and the only things I did install was the steering linkage which I think I didnt need. Also put the bracket for brake lines that goes on the driver side. Easy install. Get the gap guards makes a difference. Step bars cover up the frame pretty good. Helps out if you clean out the frame and apply a coat of paint. You will also have to move up the rear bumper or it will have ugly gap.
Rebelution
San Antonio, TX
How exactly do you pick up the back bumper? I was thinking I would just drill some new holes in the frame. Is there a better way?
TheBigler
Mobile, Alabama
yeah i was wondering the same thing because i have a friend that wants to sell me a 3' bl that wasnt installed for 60$ and i was worried about the bumper sagging
wicked2000
El paso TX
I had to make some cuts on the frame. I then welded it and added a bolt on each side. i will try and post some pics
inthechateau
Maryland
Wicked2000, I see a little more than a body lift under that truck. What other suspension parts do you have on that truck? Looks nice, kind of the direction I want to go on my 96.
_Dylan_
STAY FROSTY
I'm sure the guy that hasn't been on since last July is going to respond right away...
The answer can be found in a quick search.
http://www.tahoeyukonforum.com/forum/showthread.php?t=10714
hiltz0517
