2" front lift. Still rubbing
Gelein83
Installed the rough country 2" front leveling kit. Still runs tho. Guess I need to cut a little. I don't want water getting all up in the engine compartment though. The rain is bad in Oklahoma. Anyone know any good ways to keep from rubbing without having holes in the wells? image.jpeg
Gelein83
Gelein83
Oh. 295/25/28's by the way. Wheels are 34" tall.
al2fast
Wisky
I trimmed mine and retained the liners fully intact. Used a heat gun to reshape. Ive only got 33" tires on 20x9 with 0mm offset. Where are you rubbing?
Gelein83
Gelein83
It's rubbing mostly in the bottom front of the wheel wells. Even with the 2" front lift. I need to figure out how to move them farther forward without cutting holes. I don't want it to be ghetto rigged.
Jonah52
Senor ******
Cleveland
Smaller wheels. Bigger lift (with drop down bracket). If you cut the liner there's a good chance water will get in much easier.
01Konvict
Boats n Hoes
Raleigh/SML
Can trim the fender liner and do it right not looking ghetto but need bigger lift to clear 34" tires.
Gelein83
Gelein83
I don't want it lifted more. It looks good where it is. I guess I'll try to heat gun method. It doesn't seem to need a whole lot more clearance.
thigaustin
