Diggerdan11
So i have 2 weird issues going on with my Tahoe right now and im not sure what exactly is going on.
#1 When i turn my AC on (especially when i turn on MAX) there is a weird clicking sound. it sounds like a ticking clock and is every second like a clock. The sound seem to be coming from under the dash and is much more noticeable from the drivers side. When I turn my HVAC off the sound goes away, when I turn it back on the sound comes back after a bit
#2 there is a humming sound coming from the brakes. You know the sound ABS make when they kick in, well that’s the same kind sound my brakes are making, but this happens right after you start up the Tahoe and put it into gear. It does not do this all the time, but it seems to be worse after the Tahoe has been sitting for a while, like when I drive it for the first time in the AM. You can feel a slight vibration in the brake pedal when it makes the noise. It does not make this noise when driving, and it usually only happens after sitting for a while
Does anyone have any idea what might be causing these 2 unrelated issues?
