2000+ rear air suspension
Blazed
Accepting Donations
So that's why you always see town cars leaning one way or the other..
So I'd be better off with the double bag type?
---------- Post added at 05:34 PM ---------- Previous post was at 05:34 PM ----------
All the bags I see on eBay are the double type.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
tbss bags priven.for years. notch take ten minutes to do with a dremmel.
6500 lbs towing also. and you can get s onboard comoressor system.for cheap if you wanted
livingez_123
Sandy, OR
tbss bags 120
airlift wireless.air 400
done and more.lift.and.can.tow.6500 pounds
Only 6500lbs?
My Denali is rated for 9k and I use every bit of it... and maybe even a tad more at time's. So going to a single bag I would lose towing and if I stay with the double bag I will retain all of the GVWR. I know most of you have your rides lowered but I will be staying close to stock height. I have seen so many different setups online it's hard to decide what one is best. I could get some aftermarket air shocks and call it a day but in the end I like how the bags ride and when not towing you just drop the air down to your level ride height.
yates ™
yates ™
Resident Apple hater
Iowa
I still haven't had a chance to get a truck in to fab up the compressor housing, hopefully I can get this done soon.
Blazed
Accepting Donations
Your setup will run 2" drop at ride height correct?
Obviously adjustable. I'm talking about the height the bag was designed to run at.
yates ™
yates ™
Iowa
That is correct sir.
Blazed
Accepting Donations
What size are the air fittings on your kit going to be?
Goodinblack
I Like Tacos
Dirty South
Lbs add up quick ........
Just think the avg person weighs about 200 pounds....... times 4 plus the driver....... then luggage...... then if you tow.........
Blazed
Accepting Donations
No offense but where is this going?
dylansmashed
