2000 tahoe fuel line replacement help
jlittman
Hi: I have a 2000 Tahoe LS, 4WD, disks 4W, 5.3L. I am finishing replacing my old brake lines with SS (Inlinetube) and want to take this opportunity to replace the deteriorating fuel, return and vent lines. How do I release the fuel line clip on the back of the engine. I can barely reach it. Hopefully I don't have to remove the manifold, the gasket is good, having replaced it 2 years ago. It is not obvious to me that improving bottom access by disconnecting the propeller shaft from the front differential will help much. I welcome any advise from anyone with experience.
thanks
jon
J
jlittman
No, this is where the steel tube is attached to the back of the engine to keep it from vibrating.
Walkinblessin
