2000 tahoe rear windows problem
Dante
I have a 2000 chevy tahoe(newer body style). When i got the truck used all the windows worked perfectly, but soon i started having problems with my rear windows. I noticed the rear windows started getting touchy when i tried to use the main control panel to roll them down and the back switches hardly worked at all. I started having to barely put any pressure on the window switches to get them to roll up/down. I then noticed the 2 rear window, and lock/unlock switches would sometimes be lit up and sometimes not. Now my rear windows wont roll down at all. It sounds like they want to when i try to roll them down, i can hear a "click" when i push the switch.
Any ideas whats causing this problem?
gdddup
NJ
its prolly the switch if u had recent problems with both back doors. but pull the rear door panels n use a test light or meter to see if u have power at the motor wile opperating the switch
D
Dante
Ok,Also On my way to school this morning i tried the rear driver side window just to see what it would do and it started to go down and only made it about a half inch and then stopped.
SLOGoing
