you'll probably have better luck searching 2001 or even 2002NEED HELP !!! 24 pin Wiring Harness’s and 9 pin Harness
These are all messed up and not connected properly. Also need PCM diagram pinout diagram for 2000 GMC Yukon (New Body style) with Amp NO BOSE Stereo
Thank You
Yeah I was thinking that same thing but don’t live close to one that might have one. And if so not modified already. Seen lots that have might just have to go buy a manualyou'll probably have better luck searching 2001 or even 2002
2000 was a year they made obs & nbs, so much mixed info out there, searching a later year is always a better option.
just keep in mind changes were made in 2003 so that can lead you wrong as well.
not sure what you are trying to accomplish, the base gm radio amp is behind the glove box.
a good point of reference may be a junk yard for a hands on look for correct wiring. you could even cut out what you need or take pictures.
https://67-72chevytrucks.com/vboard/showthread.php?t=774233 These folks have a lot of electrical info. I searched on this site and came up with this 2001 electrical info. I'm sure there is moreYeah I was thinking that same thing but don’t live close to one that might have one. And if so not modified already. Seen lots that have might just have to go buy a manual
