Rivieraracing
So are you only running straight water or did I miss something? If straight water, just drain it and fill with 50/50 coolant and be done with it? If you already have 50/50 coolant in there, as long as you flushed if all out good with a hose ai don't see a reason to drain it and refill with new coolant unless it looks pretty dirty!
My denali usually always runs at a click short of the needle being straight up in center, and you did pretty much everything I would have done with replacing all the parts you changed out! Keep us all in the loop with your results!
