One of the grounds to check is the one in this video at 2:30. Supposedly it should connect to the engine block, but if the firewall to driver's side head ground is in good shape that should suffice.
Thanks for the video, but that has already been remedied on his truck. I think I mentioned it earlier in this thread, but when he got the truck, the PO had spliced the two ground wires that go to the rear of the passenger head in the same manner as this video shows.
I don't like/trust butt connectors, especially the el cheapo ones like in this video, and the ones that the previous owner had used to make the repair so I had my buddy solder and heatshrink new wires onto them and ground them at the stud on the firewall.
I believe one of the two wires is the ground for the coil packs and the other is a ground for the oil pressure sensor but I'm not 100% sure.
I am skeptical that the braided ground strap is making good connection so that will probably be left in place but a new ground added to it between the firewall stud and the side of the alternator bracket, along with cleaning up the negative battery cable where it bolts to the engine.
Tech 2 should be delivered Tuesday so maybe we can get a better idea of what is actually going on next weekend. I will keep you all posted.
