2001 Tahoe 4 wheel drive problems
t_vinson
Ok, so I replaced the switch and that did not fix it! I bought a new transfer case motor and now I have a new problem! The new motor is supposed to come with the actuator in 2 wd, but I can't get it to go on the shaft on the transfer case. The shaft won't turn to where it needs to match the actuator. Where should the shaft be located to be in 2 wd? Also, where are the relays, if any, for the 4wd control? Is it the PCM? I try to turn the shaft on tc to match the new motor, but it is just springy and I cant get to turn...any Ideas?
witty_name
