- Joined
- Jan 3, 2011
- Posts
- 50,268
- Reaction score
- 16,827
2nd opinion...
2nd opinion...
Recirculate will not work unless the AC, or defroster is on, or vehicle is under heavy load.
I could be wrong here, but if you have the heater on , and hit the recirc button it will flash 3 times then go back to outside air. So unless you have the AC is on, and temp turned to full heat I don't see how recirc could work in regular heat mode.
My 2000 Yukon does the exact same thing. ENgine comes up to temp, tstat is fine, but low heat from the heater.
I back flushed it last year, not much of an improvement. I guess I will live with it. Major PITA to replace.
My 2000 does it, but only with the rear heat/ac... perhaps I don't have the 1.21 gigawatts of electricity I need to make it all the way back there
Don't forget you may also need to get up to 88 mph too....
Just went and picked the truck up. Heat appears to be working alot better. It gets hot enough now to just about burn your hand. I would say the heater core was indeed the culprit. The only downside is the top of the dash with the defroster vents is loose. Is this easy to take off and try to tighten back up, or is it normal? Also got a P0300 on the way home, so I gotta look into that but at least the heat is working!
