2002 5.3 intake manifold gasket replacement.
JonnyTahoe
Minneapolis
Good idea. I will definitely clean everything.
Sent from my moto g(7) play using Tapatalk
And replace the Oil Pressure Sensor that was right there in the back of the engine.
Larryjb
I'd do the valley pan gasket too for sure, and perhaps the camshaft sensor. The reason I suggest the camshaft sensor is to replace the gasket. If you ever get an oil leak, you can be more confident that it is not coming from above if you replace those items.
R
R422b
Oklahoma
Hmmm if I ever.....
R
R422b
Oklahoma
View attachment 276466 View attachment 276467
I will have to call the dealer tomorrow because on RockAuto all I am seeing is wave or standard motor products. I try to use all ACDelco on my vehicle unless there is a better brand.
Larryjb
Hmmm if I ever.....
Has your rear main seal been done yet? If not... have fun one day! :devilfinger:
The rear main seal itself may actually be good, but the rear main cover often leaks badly. Unfortunately, you have to tear things apart just as much to replace it. Don't ask how I know!
R
R422b
Oklahoma
Knock sensor harness, too.
Any recommendations on brands? I am looking on RockAuto and I can't tell if any of the AC Delco ones are actually the whole harnes.
R
R422b
Oklahoma
I did that the first time I pulled the transmission. [emoji16] The front of the engine is wet with oil though.
I have been planning on changing the belts, idlers, harmonic balancer and front seal.
OffBrandCornDog
