2002 Chev suburban LT DR2 mirrors..Heat does not work
Woodblocker55
I'm on my second passenger side mirror from the junkyard that the heat don't work .. I think I found the + and - I think if there across from each other . Does anything know witch wires are the heater on mirror side are they one end and across from each other . I did a continuity test and there's none to be found. On the mirror side.. but there was 12 v on -+ on the end of plug suburban.
Sent from my LGL722DL using Tapatalk
Scottydoggs
NJ
you might be able to buy just the heated mirror on its own. ive bought them for other cars ive owned in the past. check ebay and amazon. or just google it.
the mirror back will only have 2 metal tabs if they are heated and not turn signal or autodim, if they are autodim they will 2 more small sized tabs on the opposite end
Woodblocker55
Woodblocker55
Ok I ordered a couple passager side mirrors heated with arrow and another one without arrow to test .. does someone sell driverside heated with auto dimming with arrow. I take it auto dimming takes couple wires also ..
I could not pop old one out without braking it . I need some long tools to get to then clip hooks it'd be nice if you could take it out without breaking the mirror cuz a lot of times it's just the connections.
MrTibbs
