this is the positive. Note you can splice into this by pulling the fuse block apart Make up two 8 inch 10 gauge wires with eyelets and female blade connectors. Bolt these to one of the studs. Now connect them to 5 pin automotive relays. I know your wondering at this point huh where what. I will post pics of the relay and wiring diagram later on in the post
Chris, where is the green AC positive wire found around the fuse box? What are your thoughts about re purposing the OEM relays at the end of the harness. It uses 3 4 pin relays instead of 2 five pin ones.
View attachment 227509 I think the relay block at the end of the OEM harness is built to power both relays by way of single power connection to the fusebox. Here is shot of some electrical diagram that may make sense to someone right away, but I need a primer. I think these relays are in some kind of series, and the small blue wires are speed control from the PCM.
View attachment 227510 I don't think I need the two 8 in pieces above. I see 4 post under the fuse block. Two are red,one is black, and the last has nothing on it. I'm assuming either red one is fine for power and the black one is for ground. what is the last one? Here are pics of what I have:
In the block, the green wire is likely the AC positive, and I bet the two smaller blue ones are joined into the plug pic below. This plug doesn't exist in my 00' so I'm guessing this is PCM related. I wonder if the green one is for the AC positive? Because looking at the bottom of the box, above it looks as if on set of fan wires black and yellow are organized slightly different, and that green wire is closer to one than the other.
