2002 tahoe rear differential cover size
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
12 Bolt? I thought they quit using those in '91?
There are two 14 bolt rears, a 9.5" semi-floater and the full floating 11.5" used in the 3/4-ton trucks. The semi-floater is used in the 1/2-tons under certain circumstances.
https://yourcovers.com/differential_covers.html
you are correct, it is a 10 bold design, was looking at the illistration and it counts 14 bolts
D
driven_mad
Do the nuts tend to break, anyone have any advice for removal? Mine is 2002 - 17 years old - lots of rust and leaking
We don’t get rust up here but the only problem I’ve heard of is rounded off bolt heads in the rust belt. Be aware there are either SAE or metric bolts depending on the vehicle and it seems there’s no sure fire way to tell which you have without pulling one and checking. I pulled a top one (so less chance of a leak, there’s no fluid at the top) and took it to Ace to verify, then ordered a new set to have on hand.
Jeff Groves
Retired Demo Expert. I don't need to run anymore!
Nevada, Ohio
In the rust belt rusted bolts on the cover can be a problem. You never have a socket to fit them depending on the rust. Try a Gator Grip socket. They work pretty good and I use them a lot on my job sites.
1 Gator covers a wide range of sizes so I don't need a bunch of sockets in my tool pouch.
Use an Impact driver and if the bolt is stubborn? Give it a tighten/loosen action a few times.
Generally that will get them to come out.
If that fails? Do the melted candle thing. That almost always works.
D
driven_mad
Well the bolts came out even tho they were rusted down to 12 mm but a brake line cracked due to the rust
Kerrick k
