ldreidjr
I have a 1999 Tahoe that I am always adding customization to. I have easily located the right side horn, which is right up top behind the grille. Could anyone tell me where the second horn is located? I have read that it is behind the Bowtie on the inside of the grille. Is that correct??
I wanted a loud horn, so I bought a Wolo Model 14. I want to install it the easiest way possible utilizing the wiring to either of the oem horns. Can anyone give me some simple instructions on the easiest way to wire it in with the wires that already run to both oem horns? If doing it that way wont work, please give me some instructions on wiring it in using the relay that came with my new horn. Thank you so much! Dale
Kerrick k
