2002 Yukon, 140k miles, Fixing up over time
T
tgui
Some water in the pan after a TON of cleaning. Otherwise everything looks nice I think? This is the first ever trans pan I've dropped. From what I read the color is good, not burned smelling and not a ton of debris in the oil and nothing major on the magnet. 15k-30k miles on this trans from a HD truck with a 454.
Thoughts?
This is how I did it without a proper stand. I of course made a mess but I really really wanted to see everything that came out without disturbing the pan too much.
T
tgui
Got some ebay parts.
Trans dust cover cheap, needs cleaning.
Front driveshaft from a HD truck. This is long enough.
4x4 end thingie for the trans. (transfer case adapter) Now I need a shorter 4x4 output shaft.
Baby steps...
T
tgui
Got a trans cross member for $20, need to clean, cut and mount for the trans.
T
tgui
Tear down. Found the wiring harness main connector to be damaged, I'll replace the whole harness just in case. Everything else is looking good.
Random pics, not terribly interesting:
Big picture pic to help remember where things go.
To get the valve switch (I think its called) don't yank as o-rings might come off or get damaged. Twist and rotate down and it comes off.
Check balls out and inspected. Look OK. Dinner time...
T
tgui
Took pump out and some stuff fell out.
---------- Post added at 01:19 AM ---------- Previous post was at 01:18 AM ----------
T
tgui
Still going slow on the trans. I did get my hands on the dust cover. It appears the flexplate exploded. No joke. Edged are chipped off and the housing is a tad cracked. Nothing to stop it from working though. Anywho I was able to clean it up nicely.
DT360
