2002 Yukon, 140k miles, Fixing up over time
T
tgui
Got a driveshaft coming. $85 on eBay. I also found a local shop to shorten it. What a slow process this has been.
T
tgui
Got it! Now to install tonight. I hope this fixes no AC at stoplights!
---------- Post added at 09:03 AM ---------- Previous post was at 08:59 AM ----------
The first driveshaft deal fell through. The seller couldn't find it in their warehouse. Welp, I got an even better one for cheaper!
This is from California and lacks the thick rust the east coast driveshafts have.
T
tgui
My AC works great so far! Shut off your engine when warm. Try to spin the fan by hand. If it does with ease your clutch might be toast. Also, if your engine fan doesn't roar when starting up cold your clutch might be toast as well. There was a huge difference when spinning the new one as well.
I used this video to install. FYI I added a tiny bit of anti seize on the first couple threads to overcome issues screwing the new fan clutch on. It's self tightening so it won't fall off ;)
http://youtube.com/watch?v=OILjCcQwy60
T
tgui
Did drivers side rear dust shield. It was OK before the winter. It turned to a rusted ************* by now. I used the other dorman two piece part. No need to remove axle shafts. Just grind off the stock part.
---------- Post added at 09:48 PM ---------- Previous post was at 09:46 PM ----------
Got the Cali drive shaft in hand. If you're not on the east coast you won't understand how beautiful it is! My stock one is bumpy with Rust.
---------- Post added at 09:49 PM ---------- Previous post was at 09:48 PM ----------
Closer. I want to lick it.
---------- Post added at 09:56 PM ---------- Previous post was at 09:49 PM ----------
Made a lip seal tool for my trans.
Black4x4
Just read the beginning of this thread and it sounds like the last person who had it did 0 maintenance whatsoever. Glad the Yuk is getting some much needed attention. She's a beauty, love that color!
Tiki
Great thread, better commentary.
Sidebar, check out the garage journal web forum. Because hardcore everything.
T
tgui
It's simply amazing how little was done! I got her cheap though ;) Thanks for the compliments.
---------- Post added at 06:13 PM ---------- Previous post was at 06:12 PM ----------
I'll have to check that place out. Not sure I can keep up two big threads on diff forums :)
T
tgui
After this weekend, **** GM and their parking brakes. I've gotten really good at removing wheels, calipers and rotors to adjust them.
briwesric
