2002 Yukon, 140k miles, Fixing up over time
T
tgui
Xfer case rebuilt, freshened up with new bearings and modded to a 32 spline input shaft.
It took me a couple days to get the old trans out. East coast salt.
Dowels are supposed to be in the engine block, not on trans. That much corrosion took place.
T
tgui
Trans in. Testing on jack stands. So far so good, but that might change when I hit the road.
3rd rebuild of this stupid shift bracket. It works now.
ECU Rewire.
Spliced in VSS for 4l80e. Needed for segment swap.
Testing.
T
tgui
Gear selector isn't working with D. I have a cable issue. Selecting manually works with everything.
Final steps. Then the new rear differential!
Manually shifted this.
T
tgui
Trans didn't work properly. I had to pull it again. 2nd time is waaaaay easier.
I used the wrong year OD planet which stopped the OD roller from locking.
I hope the next round of testing goes better!
T
tgui
Things are progressing. Wheels move!
Now I have an electrical issue. The xfer vss isn't working, so no speedo, no shifting.
T
tgui
More lights than my Xmas tree! She's pissed off....
Madisonls98
