2002 Yukon, 140k miles, Fixing up over time
T
tgui
Didn't have a ton of confidence on the test drive.
T
tgui
This second rebuild gave me the chance to put in a nice flex plate!
You can measure clearance with a drill bit. 1/8 inch on the dot.
T
tgui
The HF cheap trans jack is great for all sorts of things.
jcevans7
Friendswood, TX
I had to put my kids down for bed and grab popcorn. As I started trolling. I couldn't stop myself from going down this rabbit hole. I know my Denali will need the front diff redone at one point. Thanks for sharing all of this. Keep it up and good luck.
Sent from my SM-N910T using Tapatalk
T
tgui
My pleasure! This place and performancetrucks.net are great resources.
T
tgui
Details are that I'm an idiot as to why the speedometer isn't working.
Wrong connection under xfer case vss extension. I haven't had time to test but feel its probably this. That and it's closing in on 15F and my garage isn't super insulated.
Purple green, not purple yellow.
Also, tests can be in on pcm red connector pins 20 and 21.
Note that xfer vss resistance is about 1600 ohms.
Like this.
T
tgui
Bad news, no shifting, P1860 code, need to research.
Good news, speedo works!!!
medooo2004
