Does anyone know which fuse it could be if thats true
The one that's blown. [sorry, couldn't resist a great straight line!]
Get a cheap test light and check fuses. Or a DVM if you have one. Either way is easier than visually checking them.I believe its one of the fuses that you cant see the inside of. The ones under the hood. Any suggestions what to do would be great. Ty
Battery cable probably. Run a jumper and check, but don’t try to start it that way.I purchase a test light and hooked up the ground to the negative battery terminal. I had power to the battery. No power to the alternator nut on back. No power to the red box below the alternator that the wire fron battery and wire from alternator meet.Any suggestions would be great. Ty
